Hat voltage +-18V [SOLVED]
Posted: Sep 27th, '14, 07:03
by bleah
Any troubleshooting hints for -+18V when measuring U7 voltages?
Re: Hat voltage +-18V
Posted: Sep 27th, '14, 13:48
Dear bleah,
Measure C88* and C89* voltage. Check the polarity of this capacitors too.
Are the other ic's voltages -15v , +15v ?
Do you already solder U7 ?
Have a look on the HiHat schematic then test all +B3*, -B3* voltage.
Posted: Sep 27th, '14, 19:39
by bleah
Well, I don't quite understand what happened but now U7 voltage is around +/-15V after I build the Master section.
I have socketed U7 but I tested voltage again without IC in place and voltage is good.
All other IC voltages have been correct.
Polarity of C88 & C89 are correct.
So it seems that I don't have problem anymore.
