What is going on with this Yocto. Is there a way to initiali
I tried powering on/off while holding start and continue, but that didn't do anything.
Hi there,
What individual out come from this HHHmmmm ? it seems to be a Tom ?
The video is the master out, but the hum/whine is from the Kick section, which had previously been working. Then suddenly all of the sequences were weird and the kick produces this whine.e-licktronic wrote:Hi there,
Please check power supply first, if it was working and nothing "burn" maybe you got an issue with your power supply
The voltages are correct on test pins.e-licktronic wrote:Please check power supply first, if it was working and nothing "burn" maybe you got an issue with your power supply
What should I check for?
If the whine is from the Kick is there something I should check there?
Now check following point:
-With a scope check that trig signal is on Q40 Collector when sequencer is running
-With a scope check that the oscillator circuit works on IC12 pin1
-Check with MM that IC12 is well powered (+15V, -15V)
Please post the results
