Clean your PCB board?
Posted: Jun 17th, '14, 15:21
by touchmonkey
I'm fairly new at this and was wondering if people clean the flux off the pcb board when they're done?
I've been researching this and it seems as though there are both opinions out there so wondered how some of you more experienced folks approach this? Is it necessary?
I'm using Kester rosin core solder 63/37 which states it doesn't need to be cleaned but seems as though some people feel it should always be done.
thanks.
Re: Clean your PCB board?
Posted: Jun 17th, '14, 18:52
by lfo2vco
Indeed, I use a big bottle of Isopropyl Alcohol. The board is liberally swabbed down using lint free cloths, taking care not to get the Alcohol in any pots and switches. Rather than leaving all the cleaning up to the end (which is a chore), I cleaned up after each session. Then once over again at the end.
I have heard that modern lead free solders are quite acidic, indeed the tip on an old soldering iron was eaten away in one session (modern tips are more robust). I think this alone makes it worth cleaning up your boards, imagine what that residue will do to the components over time.
Posted: Jun 18th, '14, 13:35
by touchmonkey
awesome. thank you.
Posted: Jun 24th, '14, 00:49
by julienvoirin
like lfo2vco -> isopropanol
Posted: Oct 22nd, '15, 06:51
by Masuto
I am not using lead free solder. How should i clean my board? Can i use proper alcohol (red colour)?
Posted: Oct 22nd, '15, 10:40
by rv0
Masuto wrote:I am not using lead free solder. How should i clean my board? Can i use proper alcohol (red colour)?
use IPA
I have this handy IPA spray and antistatic brush
do most of the cleaning before installing (trim)pots
Posted: Nov 25th, '15, 22:13
by Masuto
Cheers
