Hello fellow DIY'ers,
I am about to buy a Yocto 808 and wondered if there is a way to get the enclosure in metal since I am a bit worried that it needs to be shielded properly.
Any tips for shielding the acrylic enclosure? Perhaps put some self adhesive shield foil on the inside?
				Shielding?
The local laser-cutting place I got my enclosure built at does cut metal, you could probably get it made in metal. Probably more expensive though.Kekke466 wrote:Hello fellow DIY'ers,
zmb wrote:The local laser-cutting place I got my enclosure built at does cut metal, you could probably get it made in metal. Probably more expensive though.Kekke466 wrote:Hello fellow DIY'ers,
Where did you have yours build? I'm located in Belgium.
At a local shop in the city I live in Canada, I picked it up in person, I don't think it would be relevant for you unless you want to pay for international shipping!Kekke466 wrote:zmb wrote:The local laser-cutting place I got my enclosure built at does cut metal, you could probably get it made in metal. Probably more expensive though.Kekke466 wrote:Hello fellow DIY'ers,
you can glue some aluminum sheet inside the acryl enclosure (Roland did this in the Juno 106 as the bottom enclosure panel is wood)
