Illuminated Tact Switches: What Brand/Model + datasheet
Posted: Jul 26th, '21, 15:36
by metro_electro
Hi everyone,
What brand and model# are the illuminated tact switches for the Nava (and Yocto)? Is there a complete datasheet available too?
The page on the site only shows partial information so it's not enough to know the source or part numbers.
Thank you
Re: Illuminated Tact Switches: What Brand/Model + datasheet
Posted: Aug 8th, '21, 23:19
by bizillcizole
I was searching for a replacement for one of these I installed backwards, and I think the ones in the kits were purchased in bulk from an Asian wholesaler. I managed to locate and order a part that will hopefully be a drop-in replacement. I haven't received it yet, but will post back here to let you know if it works. link:
https://www.digikey.com/en/products/det ... Eplacement.
Posted: Aug 10th, '21, 02:12
by bizillcizole
I just received the switches I ordered. The footprint and height are correct, but the actuator is too small to retain the switch cap. I'm probably going to use some mild glue to stick it on so it could be removed in the future, if necessary.
Posted: Aug 10th, '21, 14:56
by bizillcizole
If you're feeling spendy, you could get an original 909 replacement.
https://www.soundtoparts.com/en/roland/ ... d-led.html
