Is there any way to adjust the amount of noise going into the toms sound? At 130mV with a 520R resistor at R127 the snare is sounding pretty nice but the toms noise is super high to the point where it's not adding a little extra to the sound but overpowering it. Is there a resistor value or something in each tom section or in the noise section that can control the amount of noise fed into the toms?
Thanks,
Kris
Toms noise
Vincent pointed out the resistors that control the amount of noise in the toms:
Hi tom noise level = R273
Middle tom noise level = R245
Low Tom noise level = R216
I messed around with a few values and found 56K to give a more pleasant balance between the noise in the snare and the toms. Not sure if the sound is true to the original 808 or not but I really don't care because the toms sound much nicer to me now.
I've found from building the toms in the past that how you're listening can strongly affect how you hear the noise, due to background noise in your environment and how your speakers handle white noise etc. I often hear a pretty significant difference listening on my speakers vs headphones. Maybe try listening to them from many different sources to get the exact right balance?
Listening to mine on studio monitors. The noise was massively overpowering the toms sound.
mine as the same "problem", noise is too high in toms...
do I need to try different values for those resistors or do I need to calibrate other trimmers before ?
hand clap noise/decay is still too long/high for me...krisbo wrote:Vincent pointed out the resistors that control the amount of noise in the toms:
