Page 7 of 11
Re: Nava2021 (post v1.028beta)
Posted: Sep 29th, '21, 19:26
by FlavioB
3thernet wrote:Will it ever be possible to enter notes in step mode without having to "save" them to the sequence via the enter button?
Good question. But isn't this show the original 909 works? I never had one, so I don't know...
Posted: Sep 30th, '21, 03:57
by 3thernet
FlavioB wrote:G
Nope! With the original 909 you never needed to save your patterns to the EPROM, it was all automatic. Though, you weren't able to link sequences once a sequence was already running... a major benefit of the NAVA. However, on the original 909 you could edit the multiple 'pages' of sequences without needing to hit the enter button once notes were entered!
Posted: Sep 30th, '21, 04:53
by FlavioB
Ok thanks for clarifying.
But then: why the save button was added to the Nava? I had my time getting used to it (like on the Beatstep Pro)!!!
Posted: Sep 30th, '21, 10:58
by Neuromancer
I think Vincent decided to use a Save button because the TR909 uses static RAM to store patterns while the Nava uses an EEPROM to store patterns. EEPROM has a limit to the amount of times it can be rewritten.
So to reduce wear on the EEPROM you need to tell the Nava to save patterns.
I hope this answers any questions about dropping the save button.
Greetz,
Neuro
Posted: Sep 30th, '21, 13:59
by FlavioB
Thanks Neuro - that explains it quite good!
Posted: Oct 1st, '21, 19:11
by dave_angel
Neuromancer wrote:
Thanks, I don't see a way of bricking the machine when updating. Nothing fancy is being done at that moment.
Change pattern is implemented using midi notes. See the wiki or release notes.
https://github.com/BenZonneveld/Nava-20 ... /wiki/MIDI
My current priority is implementing pattern groups in step or tap mode.
Neuromancer
Oh wow! Didn't see external pattern change was already included in the firmware! Great news. Thanks for your reply.
Thanks again
Posted: Oct 2nd, '21, 18:40
by Neuromancer
As I just changed my audio interface setup I'm not sure if it's the Nava or the interfaces/Asio/Cubase messing things up but....
When using the Nava as a MIDI Slave my sounds seem to be played ahead of the beat making it impossible to get the Nava in sync with myother parts running from Cubase.
EDIT: The latency problems where caused by Cubase/Asio, not the Nava.
Also, first time in 7 months I made a track.
Posted: Oct 5th, '21, 15:21
by dave_angel
Love that feeling!
Posted: Oct 5th, '21, 16:54
by FlavioB
Let's hear this track then!
Posted: Oct 5th, '21, 23:50
by Neuromancer
Here it is.
2 Parts of 303
several parts of Prophet X and Prophet 12
and my Nava.
Greetz,
Neuromancer
