A new beta version is available containing several bugfixes and minor improvements.
Available here: https://github.com/BenZonneveld/Nava-20 ... o-20210918
Nava2021 (post v1.028beta)
Thank you!Neuromancer wrote:A new beta version is available containing several bugfixes and minor improvements.
I installed it some hours ago and I already enjoy the solo feature - great addition!
BTW: is anybody taking care of the PDF manual update?
I tried to get the current documentation as up to date as I could using the wiki option on github.FlavioB wrote:Thank you!Neuromancer wrote:A new beta version is available containing several bugfixes and minor improvements.
Oh, right... Github! I forgot that the doc is updated there... I'll check it later, but thanks already!Neuromancer wrote: I tried to get the current documentation as up to date as I could using the wiki option on github.
F.
I forgot, I also added an option to have manual control of the accent or the stored accent value.
You'll need to implement this schematic to your Nava for it though. Can't help with how to do it.
https://imgur.com/gallery/SSu7j0M
OK, sounds interesting, but I already have the Extra9+ mod and case, so I think I won't be adding anything to my Nava...Neuromancer wrote:I forgot, I also added an option to have manual control of the accent or the stored accent value.
F.
Thank you so much for the latest update!
Some great additions!!! So grateful to all that is continuing to work on the firmware!
Is there any risk of bricking the machine when updating? Just hesitant and thought I'd check is all
Do you have a list of items that will be added at some stage?
Change pattern via pgm message + track length per instrument are by far my most desired additions.
(And inverted mute light option but that is in an ideal perfect, all dreams come true kinda way)
Thanks again and all the best to all x
... i had no luck this time. after flashing the recent build the device is not restarting by self. switching it off/on results in all leds and display lighting constantly. i can access bootloader mode and flashing seems to work too. but it makes no difference which build i tried to flash it will result in the same issue. is there still anything i can try to reanimate the device?
thanks in advance,
todd
edit: setting output buffer to 32 solved the issue and firmware flashed successfully. nice shocker on a sunday afternoon
thanks in advance,
todd
Thanks, I don't see a way of bricking the machine when updating. Nothing fancy is being done at that moment.dave_angel wrote: Some great additions!!! So grateful to all that is continuing to work on the firmware!
Change pattern is implemented using midi notes. See the wiki or release notes.
https://github.com/BenZonneveld/Nava-20 ... /wiki/MIDI
My current priority is implementing pattern groups in step or tap mode.
Neuromancer
Will it ever be possible to enter notes in step mode without having to "save" them to the sequence via the enter button?
