4558 inserted in the wrong way (fried?) [SOLVED]
Posted: May 26th, '14, 16:30
by gihaume
Hello,
I think my HT/HC doesn't work because at first I put the 4558 in the wrong way in having forgotten to remove power supply in the same time. So quickly a very bad smell came and I found that I have powered this 4558 inverted and unsoldered, (so maybe some pins were connected and other ones not).
Do you think I have fried it?
Guillaume
Re: 4558 inserted in the wrong way (fried?)
Posted: May 26th, '14, 16:42
by Dr.Knob
AOP generally are fragile. If you have no spare malaysia 4558, you can try with something else, for example a TL072 or JRC4558D.
Posted: May 26th, '14, 17:22
by gihaume
Thank you!
I found a lot of "TL072" on Conrad, which one do you think is accurate?
Posted: May 26th, '14, 17:53
by Dr.Knob
Ref: 1011512 - 62
TL72CP is ok, itsn't the original component but it'll work this. I'm building a TR8060 with TL072, it doesn't change much.
This must have less difference between malaysia4558 and JRC4558D.
Posted: May 26th, '14, 18:40
by gihaume
Merci!
Posted: Jul 11th, '14, 20:22
by gihaume
I finally changed the 4558 with a same one from another Yocto kit because the TL072 I ordered doesn't have a similar mark for the good way to insert it and I wanted to be sure. So I put a new 4558 and unfortunately the high tom still doesn't work...
Has someone an idea of which part could have been damaged when I put the 4558 in the wrong way?
Posted: Jul 12th, '14, 11:21
by gihaume
I only hear the noise part of the sound in the High Tom sound, plus a little click when the Tuning parameter is high.
Also when it is accented, the click sound is higher, and also present even if Tuning parameter is low.
Posted: Sep 19th, '14, 01:28
by gihaume
I finally succeed to resolve the issue with my high tom.
The desoldering of the 4558 was obviously difficult and many solder points were damaged. I did the continuity tests to be sure that every point was well connected to its track. Unfortunately the point 3 corresponding to ground was not visually on a track and I thought it was not planned to be connected, but it was this one which was deconnected!
