I just received my yocto kit and going through the components I can't find the 1n5822 diode anywhere! I looked through the active components bag several times, as well as the other bags just in case. It's possible I misplaced it somehow and my post will look silly, but I can't find it anywhere in my workspace here. So I have a few questions.
1. Is it in its own small bag in the larger active components bag? If it was meant to be in the same bag as the germanium and 4004 diodes (as indicated by the components list) then it's definitely not there, but if it's in its own little bag then it's still conceivable that I've dropped it on the floor somehow.
2. Is it necessary for turning on the yocto and testing it? Obviously I'm going to replace it for the final build, but in the mean time can I safely plug in the yocto and test it? It looks like it's only used for regulating the 5V supply. Otherwise I'll have to put the whole project on hold until I get this one little diode...
3. Is there a good substitution? My local electronics dealers don't seem to have that particular model. I've been looking into equivalents but to be honest power electronics and diode specs are a weak point for me. I'm not sure which aspects are important for its role in the PSU... voltage drop, current leak, breakdown voltage, etc. etc. What are some options?
Thanks for any help. I'm just very excited to start building this and I don't want to be held up by one little diode!
Here's a crappy picture but you can see that there are only 6 germanium diodes and 7 4004s.
Missing diode 1n5822 [SOLVED]
Thanks, I ended up just buying one from Jameco along with the power supply, and in the mean time I will just test it using a different power supply. I posted this in haste, a little too excited i guess, but problem solved.e-licktronic wrote:Dear zmb,
Contact Vincent for missing part :contact@e-licktronic.com
