Ok so I got to the handclap and tested my instruments with Arduino.
2 problems.
1. SnareDrum - I can hear only "pop" sound nothing else. Sound is changing when I move potentiometers.
2. HandClap - Didn't tested it yet because I get only -13.3V on AN6192 - i didn't solder BA6110 and AN6192.
Any help?
Problems during build [SOLVED]
Dear vereggaet,
It seems that snare nois part don't work.
Is VR9 ajust the noise volume ?
For the handclap: it will be better if you add IC socket to test, but only -13.3v will not destroy the BA6110 or AN6192.
Vincent
Vincent
yes the VR9 is adjusting the volume.
For handclap i soldered both IC's into place and when I connect 5V from Arduino to test it, my Arduino stops working like it's a short somewhere. Oh and I don't have a switch soldered, can this be problem?
It has no relation. Be sure your Arduino ground connectedto the Yocto ground.vereggaet wrote:For handclap i soldered both IC's into place and when I connect 5V from Arduino to test it, my Arduino stops working like it's a short somewhere. Oh and I don't have a switch soldered, can this be problem?
Yup ground is connected to Yocto ground. That is how I checked all other instruments. I just finished cowbell and all I hear is "pop" sound again.
I will check for wrong components and bad solder joints and will report here.
Ok so I finished my Yocto and these are the problems:
!. Bass drum was triggering with Arduino, now I have no sound from bass drum. I checked all components they are all right values. No bad joints, bridges..where to look for this problem? Maybe fried transistor?
2. Handclap - no handclap, only loud noise when TM3 turned CW, CCW I hear no sound
Thanks for help!
Thanks for help!
Any help?
what you describe might be a totally different issue, but I was having problems with my handclap that were solved once I replaced the two transistors Q28 and Q29.
OK I solved my YOCTO problems.
I changed Q39 and now my bass drum is working!
For the handclap i was missing a switch, so when it arrived I soldered it, adjusted the trimmer and now the handclap also works.
So now I have fully working YOCTO..NICE
