[SOLVED] Crash too loud and distorted
  • Ok, so after building a DSO150 oscilloscope and a bit of debugging i narrowed it down to the 2SA798 in Q70. So i swapped the one from Q68 over to verify my suspicion and the crash started to work as it should. Vincent said he'll send me a replacement so case closed :)
    The takeaway here: Always test your transistors before soldering them if you can!
