Trim potentiometer (254P)(SOLVED)
Posted: Mar 26th, '14, 18:44
by seven
Need a replacment Trim potentiometer (254P) , the screw head got broken when turning(I can just turn it but needs replacing),
Went here
http://uk.rs-online.com/web/c/?searchTe ... ra=oss&r=t
but they need more info to find me a replacement...
"To be able to identify an alternative for you, do you know the power rating of the trim and the maxium resistance?"
This is what they need to know above.
Re: Trim potentiometer (254P)
Posted: Mar 26th, '14, 20:42
Dear Seven,
Here is the
datasheet of the 250Kohm 3362P trimmer
You can find this trimmer
here
Posted: Mar 26th, '14, 21:08
by seven
e-licktronic wrote:Dear Seven,
Here is the
here
thanks, can you have a look at our cowbell thread/issue too? Thanks...
Posted: Mar 27th, '14, 02:52
by seven
Here is the
here
WARNING OTHERS HERE: The data sheet is the wrong PDF, the item code is 3362P-1-254LF for ordering spares!
Posted: Mar 31st, '14, 10:24
I don't think so, why did you say that the datasheet is wrong one ? Have a look on "How to order" section on the datasheet, you got the 3362P-1-254LF ( it meens 3362P series, standart product, 250k ohm, 100% Tin-plated)
Posted: Apr 11th, '14, 00:32
by seven
e-licktronic wrote:WARNING OTHERS HERE: The data sheet is the wrong PDF, the item code is 3362P-1-254LF for ordering spares!
My apologies, It shows how to order yes, I read it as that was for a different one(the code example), but it is indeed covering 3362P-1-254LF
I thought they had upload a different PDF by mistake.
