Need a replacment Trim potentiometer (254P) , the screw head got broken when turning(I can just turn it but needs replacing),
Went here http://uk.rs-online.com/web/c/?searchTe ... ra=oss&r=t
but they need more info to find me a replacement...
"To be able to identify an alternative for you, do you know the power rating of the trim and the maxium resistance?"
This is what they need to know above.
Trim potentiometer (254P)(SOLVED)
I don't think so, why did you say that the datasheet is wrong one ? Have a look on "How to order" section on the datasheet, you got the 3362P-1-254LF ( it meens 3362P series, standart product, 250k ohm, 100% Tin-plated)WARNING OTHERS HERE: The data sheet is the wrong PDF, the item code is 3362P-1-254LF for ordering spares!
My apologies, It shows how to order yes, I read it as that was for a different one(the code example), but it is indeed covering 3362P-1-254LFe-licktronic wrote:I don't think so, why did you say that the datasheet is wrong one ? Have a look on "How to order" section on the datasheet, you got the 3362P-1-254LF ( it meens 3362P series, standart product, 250k ohm, 100% Tin-plated)WARNING OTHERS HERE: The data sheet is the wrong PDF, the item code is 3362P-1-254LF for ordering spares!
I thought they had upload a different PDF by mistake.
