Hello All,
One of the thing I like most about the 808 is the fine tempo knob - I often use the 808 in a DJ set and 'beat mix' it with the records. This is hard without a 'Fine Tempo' knob like on the original..
Was even thinking of using a Technics SL1200 Sized Fader to control the fine tempo as I might use a non standard enclosure...
Fine Tempo Knob - How to add
Dear Discodisco,
Actually Yocto do not provide fine tempo.
You need to connect your SL1200 fader to an ADC of the Atmega1284p to remote Yocto tempo, unfortunately all ADC pin are in use for others function.
Maybe you have an other idea to add this function
