Re: Finished Build: No Cymbal, weak Handclap
Posted: Dec 14th, '19, 18:30
I understand, no problem and thank you very much for the tips. I'll have a go at them.helectromagneticus wrote:Hmm, without having your unit in front of me it is difficult to determine what the problem is. I would proceed with the following:
I wish I could help you more, but it's quite hard to troubleshoot remotely...
- Check the orientation of your transistors and verify their pinouts against their datasheets
- Check the orientation of IC23
- Verify the connections in each circuit node by following the schematic. For example, check that R371 is connected to GND and the base of Q72 etc. This is a painstaking process but if you are thorough you can be sure that everything is wired up right.
- Verify resistor values
- Check the orientation of C144 and read the discussion about this part in the forum
