ic m5218 and transistor 2 sd1469 orientation
Posted: Jun 1st, '19, 07:56
by Oowl
hello, i m not sure about orientation of ic m5218 and transistor orientation 2sd1469 ( Q47 and Q48)
is someone can help me ?
thank
Re: ic m5218 and transistor 2 sd1469 orientation
Posted: Jun 5th, '19, 13:45
by jeroenbvo
The m5218 will have a vertical line printed towards one side. That would indicate the side of pin 1. On the pcb pin 1 is indicated by "1" and a square shape on the silkscreen.
The 2SD1469 has a little notch on the top, which corresponds to the marking on the pcb silkscreen.
you can also see it on the picture in the build guide:
http://www.e-licktronic.com/fr/content/ ... -snaredrum
Cheers
Posted: Apr 17th, '20, 14:07
by Oortone
jeroenbvo wrote:Hi,
Cheers
My 2SD1469:s does not have a notch. Seems like the upper side plastic is kind of uneven making it impossible to really see a notch. If I have the text facing towards me and legs downeards, would the emitter (1) be the leftmost leg?
Posted: Apr 28th, '20, 12:10
by jeroenbvo
Can you post a picture of the 1469?
Posted: May 31st, '20, 16:56
by Oortone
jeroenbvo wrote:Can you post a picture of the 1469?
Sorry I missed this and now everything is closed up and hidden in the closure. If I find some pictures or notes I'll post them.
