Noise: no 130mV?
  • mrgif have you read the other thread over here:
    viewtopic.php?f=16&t=155
    it has a lot of useful info. Apparently even if the values of the resistors are all up to spec it can stil lhappen that because of the 5% tolerance, you can get quite a different resistance value. so it might be worth trying out another value for R127 if you are sure that everything else worked.
    I replaced mine with a 47K and I was able to trim noise to 130mV.
    Hope that helps...
