Page 7 of 8
Re: Bugs and suggestions
Posted: Sep 3rd, '18, 18:29
by gihaume
Tight !
Posted: Sep 17th, '18, 21:18
by Dr.Knob
It's is mentioned flam with 027. But how to program flam? I can find no explanation for this.
Posted: Sep 18th, '18, 10:58
by serum114
Dr.Knob wrote:It's is mentioned flam with 027. But how to program flam? I can find no explanation for this.
Select the snares flam by holding instrument select and steps 3+4.
Posted: Sep 18th, '18, 18:42
by Dr.Knob
Ah, oh it does not work, but i just saw that there are 2 versions of 027, one with flam and the other without. I probably had to load the one without.
Posted: Nov 13th, '18, 01:42
by mkho
EDIT: Can't reproduce the bug.
Posted: Dec 27th, '18, 18:14
by mkho
Okay v1.028 issues here:
SLV mode
1. tempo no longer displayed on OLED when pressing and holding tempo button.
2. (shift + num) gives you a 'rastering' OLED screen. The lines appear to crawl?
Posted: Dec 29th, '18, 19:35
by zabox
1: It‘s been like that in all previous versions, showing that your nava is detached from the internal clock (in slave mode)
2. Good catch, the display is constantly updating with that button combination. I‘ll fix it in the next major update, as it‘s only a small cosmetic bug. It doesn‘t impair performance
Posted: Jan 1st, '19, 18:01
by pete303
Hi, I don't know if this is a bug really or if this would be also the case with a real 909. When I have my Nava (V1.028) externally synced (to a Innerclock Sync Lock) it is perfectly in Sync with the Metronome in Ableton. As soon as I change the Swing Parameter, it slightly gets out of Sync to the Metronome. Stopping and starting again heals it, means then the Nava is perfectly in Sync again.
Can you reproduce this behaviour on your machines?
Thanks in advance!
Posted: Jan 4th, '19, 17:19
by zabox
Mh, on some occasions i could get it to jump one 1/16 note, but not to a slight offset as you describe it. But i noticed that the shuffle is completely off, only half as strong as it should be and in slave mode there‘s only one working shuffle variation (0-4 off, 5-7 on).
I‘m sorry that i didn‘t notice this earlier, but i‘m going to rewrite the shuffle function and match it to a real 909
It may however take a few weeks. If anyone needs an earlier fix for some reason, i can ask vincent to upload a quick and dirty patch that i‘m already running on my nava. (But right now it only works in the regular 16th note scale).
Posted: Jan 11th, '19, 09:42
by pete303
Hi zabox, that's good to hear, and yes, a qick and dirty patch would be great, thank you for your help!
Peter
