Page 1 of 2
Soldering done, nearly there, slight sequencer issue
Posted: Apr 11th, '18, 19:05
by cablebasher
Dudes
So all the soldering is done and she’s in the metal case. Hooray.
A slight (?) issue....
The start/stop button doesn’t do anything.
However step 9 (CB) acts as a start stop button. I can start/stop patterns by pressing step 9.
Most other things seem to work sequencer wise and all the sounds work.
Oh, and the roll, mute and scale buttons don’t do anything. The 6 leds work but no action on the buttons.
I was thinking a soldering short as start/stop ,roll, mute and scale are all next to each other but that wouldn’t explain step 9 acting as start stop.
Any ideas?
Thanks as always.
Re: Soldering done, nearly there, slight sequencer issue
Posted: Apr 12th, '18, 04:07
by gihaume
Yeah... sequencer issues are always weird and pretty unknown. That's very likely that none can help you with the behavior described. Just check solder points, shorts and/or forgot parts again and again.
Posted: Apr 17th, '18, 06:50
by cablebasher
Hey man
Thanks for info.
Yeah once you enter the digital domain electronics gets a lot more complicated!
I did however get it fixed. I found on the schematic that all the things that didn’t work (start/stop, mute, roll, scale) were all controlled by IC7.
I swapped the IC but no difference so I did a continuity test and found one of the IC socket legs was broken.
Fixed that and it all works!
Well almost.
I notice the start/stop button double presses a lot.
Anyone else experienced this?
Any ideas.
Posted: Apr 18th, '18, 12:55
by jeroenbvo
What do you mean by double pressing? It has bounce?
Put a capacitor <1000pF to ground over the contacts.
I had an encoder doing that on the Nava, the caps solved it. See my post here: viewtopic.php?f=24&t=1005
Posted: Apr 20th, '18, 12:32
by cablebasher
Yes the start/stop is bouncing.
Do you have a photo of your nava with the cap fix installed?
Which is the 4 contacts in the button do I put the cap across?
Once that’s sorted I’m done!!!
Posted: Apr 23rd, '18, 11:11
by jeroenbvo
Switch S17 has only 2 of its 4 pins connected. Looking at the schematics I see the shift register is normally held low to ground. Pushing the switch makes it high.
Just bridge the contacts 1 and 3 with a ceramic or film capacitor <1nF.
Posted: May 8th, '18, 10:11
by jeroenbvo
** Bump **
Curious to know if it worked out for you?
Posted: May 9th, '18, 10:39
by cablebasher
Hey man
Sorry for he late reply.
I decided to leave it a few days as I didn’t want to open it up again.
It now seems fixed without me doing anything.
It’s weird, for the first few days every time i pressed start it doubled or triple pressed and now it works perfectly ever time.
I guess it just needed a few presses to iron itself out???
Thanks for the advice thought.
Posted: Aug 20th, '19, 09:00
by neevamerk
Thank you for advice. I also faced same slight sequencer issue while soldering.
Posted: Oct 27th, '25, 05:27
by will
Yt.be/activate is the link used to connect YouTube to your smart TV or streaming device.
Easily pair your YouTube account with your TV by visiting Yt.be/activate
Yt.be/activate is the online activation page for YouTube on smart screens.
Use Yt.be/activate to enter your code and link YouTube to your device.
Yt.be/activate helps you enjoy YouTube on big screens without logging in manually.
