Clap, Cb, Cy, Oh, Ch Help please [SOLVED]
  • Also forgot to mention that the clap is a little low on output to
  • Did you build the noise section?
  • yes noise is fine for snare/toms / kick cklick / Maracas and clap just not working in the cowbell and hats and cymbal. seems like white noise as the others or pick noise?
  • Ok further experimentation brings me to this. i have to take the noise from tp4 to tp5 and tp6 via some solid core hookup cable.
    Noise is getting to the snare and toms fine. the only issue is with the hats and cowbell. so could it be a bad cap, week via or trace? transistor? all caps have been checked and are correct orientaion and value. all resistors have been checked are correct values. transistors are correct values and orientation.
  • With the Help of Vincent my issues were solved. Bad Q9 simple as that.
