Page 1 of 9
				Noise section trimmer voltage?
				Posted: Jan 15th, '14, 20:44
				by effegee
				I don't know if it is significant, but I cannot get 130mV on pin 1 of the 4558 when adjusting the trimmer in the noise section.  The closest I can get is 120mV.
				Re: Noise section trimmer voltage?
				Posted: Jan 18th, '14, 00:45
				by Patrick
				I got arround 250mV AC but have to check on monday with a better DMM with 6 digits 0.01% Tolerance.
Most cheap dmm have in AC measurement a high Tolerance.
				Posted: Jan 18th, '14, 08:03
				Dear,
Try to change R127 Value by 4.7Kohm.
				Posted: Jan 19th, '14, 16:28
				by effegee
				e-licktronic wrote:Try to change R127 Value by 4.7Kohm.
Changing it to 18K seems to work.  I guess the proof will be when it's all put together and I can do some audio tests.
				Posted: Jan 21st, '14, 14:30
Glad to ear you say
				Posted: Jan 21st, '14, 22:55
				by 4teenth
				Hmm... The closest I could get it is 180mV...
Have I gone wrong somewhere?
				Posted: Jan 21st, '14, 23:16
				by 4teenth
				Yes, i appears so : Wrong value caps in C16, 18, and 20
				Posted: Jan 21st, '14, 23:50
				by 4teenth
				Okay.... corrected my error but still can only get down to 160mV..
				Posted: Jan 22nd, '14, 00:36
				by 4teenth
				Okay, just went through everything, tested all values of resistors and checked values of cpacitors. All good. So still confused as to why I'm getting a different minimum mV value....
				Posted: Jan 22nd, '14, 03:46
				by klingklang
				I too am having issues with trimming to the correct voltage on pin 1 of U24, the lowest I can get is about 250mV.
All components have been checked and rechecked and they appear to be correct.
However while checking for errors, I noticed that the resistor pictured for R127 does not match the one listed in the build guide.  The image is of a 47K resistor as opposed to the listed 4K7 and due to my excessive voltage problem I'm wondering which value is correct?  I currently have a 4K7 in R127.
Edit: I've just noticed that the original 808 schematic lists a 4K7 for R127, so that's likely the correct value (and the image must be mismatched).  I'll have to look for the source of the problem elsewhere.
