Hey Vincent,
received the new kits yesterday. What value shall I put into R40 on the IO-board? What was the reason for adding R40? Are there any further changes we need to know regarding new/ different components?
Also I am not sure regarding the orientation of IC's on the new Mux-SH board. Is it correct like this?
Questions regarding v1.02
Dear KlangGenerator,
R40 is a 0ohm resistor that part Digital GND and Analog GND.
On the Mux/SH board Ics have to be this way. Red line have to match inclined side of the SOIC package.
finished the IO board and placed all the resistors on the mainboard . oke , so R40 on IO board is 0 OHM resistor.
i found a few other diferences on the main board
1-handclap R215 and R216 are swapped ? or is the silkscreen wrong ?
2- hihat R454 and R455 are swapped ? or is the silkscreen wrong ?
3- sequencer IC 1 what should that one be ? i guess TL072 ?
4- IC 110 , C517 , C518 , C519 removed from main board and placed on the mux board ? i guess V1.02 can't be used without mux board because IC110 missing ?
are there more changes we should know about ?
please advise
thanks.
please advise
thanks.
1-R215 and R216 position was swapped to improve PCB layer1-handclap R215 and R216 are swapped ? or is the silkscreen wrong ?
2- Idem
3- Have a look on the tutorial, sequencer part this is explain,IC1 (TL072) replace IC110 (TL074)
4-V1.02 can not be use without Mux_SH board and all Nava with firmware v1.024 or higher
Follow the build documentation, it is updated
Ok Thanks , i see it now
however R40 is not mentioned in the build guide .
Hey Vince,
I've been a little bit reckless building my three nava's..
I've build Noise, Snare- & Bassdrum with build manual. After that I lost my patience en went with the Eagle file & BOM. Yes I can hear you thinking, why?...
Now the problem is the Eagle & BOM is V1 , where my version is V1.02 .. I checked the component numbers before placing them except when placing the resistors. So, mistakes made must be only made in the resistor department (Excl Noise, Snare- & Bassdrum)
Little bit panic here, but I compared both pcb pdf layouts piece by piece (Except Noise, Snare- & Bassdrum..)
As you and the topic starter already said. Resistor wise.
These are switched on the new pcb layout:
R215 - R216 --- HANDCLAP
22K - 10K
R694 - R691 --- SEQUENCER
220R - 10K => I've noticed R694 has become 1.2K instead of 220R
R454 - R455 --- HIHAT
22K - 10K
R40 => New on V1.02 --- I/O BOARD
R289 V1 => Gone on V1.02 --- SNAREDRUM
Now my question, is there a bom and Eagle file for V1.02? I would like to have a quick and correct way to build them. Anyway I am going to compare resistors values of the V1 bom with the building instructions for V1.02. I will post if I find any other differences.
22K - 10K
22K - 10K
R215 and R216, R694 and R691, R454 and R455 was swapped to improve PCB layout.These are switched on the new pcb layout:
22K - 10K
22K - 10K
R289 is still present on the v1.02.
Alright, Thanks!e-licktronic wrote:R215 and R216, R694 and R691, R454 and R455 was swapped to improve PCB layout.These are switched on the new pcb layout:
22K - 10K
22K - 10K
So, I did check all resistors and capacitors values. BOM & Eagle V1 VS Building guide V1.02. This is what I found. I really need your conformation before I can finish my nava's. (Because I build like V1 when I have a V1.02)
V1 => V1.0X => V1.02 =>
R699 = 1K R699 = 10K R699 = 10K (SEQ)
R694 = 220R R694 = 1.2K R694 = 1.2K (SEQ)
R124 = 10K R124 = 100K R124 = 100K (MT)
R485 = 2.2K MISSING ON BUILD GUIDE => I assume it's still 2.2K (HI)
C89 = 0,047μF C89 = 0,01μF C89 = gone (BD)
C163 = 0,047μF C163 = 0,01μF C163 = gone (SD)
C25 = 0,047μF C25 = 0,056μF C25 = 0,056μF (LT)
So my question is the value of these correct, since I am building a V1.02 kit?
R699 = 10K (SEQ) ?
R694 = 1.2K (SEQ) ?
R124 = 100K (MT) ?
R485 = 2.2K (HI) ?
C25 = 0,056μF (LT) ?
You can omit R699, R700 and C524. Those parts are used for serial programmingConcrete9000 wrote: So my question is the value of these correct, since I am building a V1.02 kit?
R699 = 10K (SEQ) ?
R694 = 1.2K (SEQ) ?
R124 = 100K (MT) ?
R485 = 2.2K (HI) ?
R694 is the backlight led current limiting resistor. I personally use 220ohms to get more brightness LCD
R124 = 100K
R484 = 2K2
C25 = 0.056uF
Hope this help
R485 = 10K
