Hi there, I am trying to modify you're dilicktal example so that it works with momentary presses rather than latched...
meaning, a midi note is sent while I hold a button, but on release the midi note off is sent.
help?
A little help with code?
Hi ceecrb1, welcome on the forum.
Try the last example of SRIO library tutorial here. I think this is exactly what you need. Simply replace CC message by Midi noteON and noteOFF message.
E-licktronic
E-licktronic
hi there..
Yeah that seems to be more what I am just looking for!
now just to work on the "SR" was not declared in this scope compile error.
I have added the library etc.. and even just trying the most basic example..
#include <SRIO.h>
void setup()
SR.Initialize();
void loop()
#include <SRIO.h>
void setup()
SR.Initialize();
void loop()
Fixed...
premission problems with the library.. I had to run the arduino program in administrator mode.
Fixed...
Hi there..
The 2nd button set arrived.. I´ve used them both this weekend..
Out of interest... Is there a way to easily make the first 12 buttons momentary and the last 4 as toggles?
I am actually using this to run effects on a profesional lighting desk, and its going very well!!
Hi Ceecrb1,
Download Ablickton code here and there are some function on the code to choose between toggle and momentary.
I think it's the easiest way to begin
Hello!
I am interested in using an LCD Display for the Lickogic Midi out.In the LCDBoard tutorial you only use the midi In.
can you help me with the code?
Dear Keylec,
Could you describe your project on a new topic that i could help you to coding
