Build finished, still many problems..
  • Start with verifying so that all components in each section are in the correct place. Also check so that every solder ok (i use an loupe myself to do this)...
  • Checked that. I suppose the next step is checking continuity of the traces for each section.
  • I had distorted clap when i was building a 9090 some time ago. It turned out to be a faulty IC, so if all your components are in the correct spot, try to see if your ICs are working order. Try to work organized on each section using the scheme for help.
  • Aarrgghh wrote:I had distorted clap when i was building a 9090 some time ago. It turned out to be a faulty IC, so if all your components are in the correct spot, try to see if your ICs are working order. Try to work organized on each section using the scheme for help.
    Hi Aarrgghh.
    How does the 9090 compare to the Nava, sound-wise? I temporarily have a 9090 at home and compared to the Nava, it sounds "punchier" at least on BD, SD and all TOMs...
    Can you tell me something about yours?
    F.
  • Review past payments and upcoming dues at homedepot.com/mycard
    homedepot.com/mycard is designed for easy card access and control.
    Monitor all Home Depot credit card activity at homedepot.com/mycard .
    homedepot.com/mycard lets you securely manage your credit profile online.
    Get complete credit card services from Home Depot through homedepot.com/mycard
  • homedepot.com/mycard ensures you stay updated on your card usage.
    Manage your credit card anywhere with homedepot.com/mycard
    homedepot.com/mycard is the fastest way to pay your Home Depot credit card.
    Stay on top of your card dues at homedepot.com/mycard
    homedepot.com/mycard makes credit card management simple and quick.
  • Use homedepot.com/mycard to set up paperless statements.
    homedepot.com/mycard offers a secure platform for online payments.
    Manage multiple Home Depot cards easily at homedepot.com/mycard
    homedepot.com/mycard gives you 24/7 access to your credit account.
    Track your spending habits through homedepot.com/mycard
  • homedepot.com/mycard is where convenience meets card management.
    Access monthly card statements instantly at homedepot.com/mycard
    homedepot.com/mycard helps you avoid missing payment deadlines.
    Securely log in and manage your account at homedepot.com/mycard
    homedepot.com/mycard keeps your Home Depot credit info organized.
  • Gain full control of your card services via homedepot.com/mycard
    homedepot.com/mycard provides real-time account updates.
    Make hassle-free payments anytime at homedepot.com/mycard
    homedepot.com/mycard is your digital key to card services.
    Stay financially organized with homedepot.com/mycard
