Now turning it (ALL) on for the first time I try TM2 adjustment Process.
"Now, power up your Nava holding the "ENTER" button. LCD should print "TM2 adjustment process". You need to adjust your LCD contrast maybe
 . Adjust TM2 to measure +5.00V at TP1."
. Adjust TM2 to measure +5.00V at TP1."I get NO LCD should print "TM2 adjustment process".. So I try adjusting TM2 but cant get +5v on TP1...
SO (I say shit! to myself)
  I try the "Init EEprom mode" by "Now turn off your Nava then turn on it again holding "START" and "STOP" button. You enter in "Init EEprom mode". You got 5s to press "START" and "ENTER" to init your EEprom. Steps leds show you the progress of the initialization."
I get NO You enter in "Init EEprom mode".".
SO (I say shit! to myself again)
 It won't play any patterns or make a sound...
The screen displays this;
Some help would be greatly appreciated.
 EDIT:
IC15 - Pins 1, 2, 3 & 7 should be connected to GND right?
Pins 3 & 7 are NOT connected to GND on my build.
IC15 Voltages
1. 2mv+
2. 2mv+
3. 5v+
4. 2mv+
5. 5v+
6. 5v+
7. 3.2mv+
9 5v+
All other pins (Besides 1 & 7 ) are connected to the correct places.
EDIT:
- All IC's are placed correctly and have +5V at the correct pin (Square)
- IC100 Re-Flowed Solder joints at IC and Resisters to IC100
- IC105 Re-Flowed Solder joints at IC and Resisters to IC105
NO change. Still wont enter "M2 adjustment process" & "Init EEprom mode"
