Page 1 of 2
Hi-hats bug in tap mode
Posted: Feb 18th, '17, 19:35
by Grizzlydj
big problem to use tap mode and play in real time - hi-hats Bug!!!
when you try to program any other instruments in tap mode - hi-hats triggered and played open hi-hat instead of closed or hi-hats cut!
!!!!! try to remove the volume of all instruments except the hi-hats and program them "closed"on every step from 1-16, then in tap mode, try to click on keys any other instrument (bass, snare toms ....) -> hi-hats thus react to pressing the keys of other instruments and it turns out a mess !!!
When this bug will be fixed?
that's just terrible! not impossible to work in tap mode .... I collected 2 nava and both behave the same problem - it is a problem with the firmware ...
Any have exactly the same problem?
Re: Hi-hats bug in tap mode
Posted: Mar 1st, '17, 14:53
by drifter7508
I don't know what you mean? All seems to work fine with mine in tap mode now since the last FW update.
Posted: Mar 2nd, '17, 13:01
by Grizzlydj
My two nava's have this problem with hi hats in tap mode:((( this is video:
https://www.mediafire.com/download/o10c1w3vmcnqb14
[/youtube]
drifter7508 wrote:I don't know what you mean? All seems to work fine with mine in tap mode now since the last FW update.
Posted: Mar 2nd, '17, 15:25
by Aarrgghh
I will try when i get home with mine. I didnt have this problem before. What version of the firmware are you running ?
Posted: Mar 2nd, '17, 18:32
by Grizzlydj
Aarrgghh wrote:I will try when i get home with mine. I didnt have this problem before. What version of the firmware are you running ?
Last, 1.22
Posted: Mar 2nd, '17, 20:09
by Aarrgghh
I just played around a bit in tap mode, and I can't say I can duplicate the problem unfortunately
Posted: Mar 3rd, '17, 09:44
by drifter7508
I can't duplicate the problem either.
Posted: Mar 3rd, '17, 20:04
by Grizzlydj
Sorry for my bad English)), I'm from Russia... you don't have this problem? did I understand you correctly? Google translate not correct)))... your navas work fine? But Vincent says obout it - this is software bug and will be solve quite soon... also in real 909 have this trabl :?
Posted: Mar 13th, '17, 15:30
Grizzlydj wrote:big problem to use tap mode and play in real time - hi-hats Bug!!!
Should be solved with the Nava v1.023 update ;)
Posted: Mar 13th, '17, 16:16
by KlangGenerator
Wow, that was quick! Thanks Vincent! I'll check out later...
Regarding C89 and C163: they are already 10nf/ 0,01uf. Is this a typing error?
