While updating the firmware I realized a classic USB GND loop sound when I hooked up the nava to an usb midi interface.
After looking at the schematic I saw there is an error in the MIDI jacks.
The GND (pin 2) of the MIDI in schould be not connected. On the NAVA it is connected to GND.
Here are the specs from MIDI.org
MIDI GND error
Please check again with your MM. Pin2 of the MIDI In Din connector is NOT connected to the Groundcomboy wrote:While updating the firmware I realized a classic USB GND loop sound when I hooked up the nava to an usb midi interface.
I'll measure it when I have it open again.
But I should not get a GND loop when connecting MIDI if it is only connected to the optocoupler.
