metal-film vs carbon resistors
Posted: Jan 2nd, '17, 14:22
by Humpink
It has already been mentioned in various topics in this forum that using metal-film resistors instead of carbon resistors in some sections will improve the audio quality (mixer/power-sections).
So is there any reason not to use only metal-film resistors for the whole build?
Do some parts require carbon resistors to work properly? (can't imagine that...)
Do you hear the difference?
Re: metal-film vs carbon resistors
Posted: Jan 4th, '17, 13:48
by mex
as always in electronics, one is cheaper than the other, and you always try to be as cheap as possible while still beeing as accurate as possible, so for example the logic part with all the leds, dont require stable resistors you can choose cheap here, in other parts like the t networks for sound porpuse, you maybe want the be very accurate or you aim for a certain sound so you have to have certain passive elements with certain characteristics.
So if you wanna live easy always buy the most expensive most accurate stuff, that will always work, but comes with a prize.
Posted: Jan 4th, '17, 16:28
by Data Jam
or if you want to be oldsql and close to the original that used carbon or metal, use the same.
Posted: Jan 9th, '17, 08:59
by anotherlin
Metal-film resistors are less noisy than carbon ones. Hence in theory, the built device will have less background noise.
From an audiophile point of view, that would be better. Otherwise for our purpose, carbons and metal-films are the same.
Original 808 and 909 were built with carbon resistors. So if you want to have the most faithful reproduction, it's carbon, not metal-film.
However, the "master section" basically just amplifies the final result of the whole 808, the "magic" (sound generation) doesn't happen here.
So it may be interesting to substitute metal films to have the less noise possible at the end.
In my opinion, the only benefit is that Mouser always has in stock all metal-film values. That's not necessarly the case for carbon resistors
Posted: Jan 27th, '17, 07:15
by helectromagneticus
Go ask this question at a tube guitar amp forum and see what happens!
Posted: Jan 27th, '17, 08:10
by Humpink
So thanks very much for the replies. I'll then go for metal film resistors since they are cheaper and the avaibility is better.
Since every 808 sounds slightly different anyway this shouldn't be a problem at all.
Posted: Jan 27th, '17, 12:03
by mex
You got any source for that statement?
I am of the opinion, noise in resistors is only happening due to therman noise, so called johnson noise.
And its only dependend on the resistor value, so if you have high value you get bigger noise, no matter carbon or metal.
But feel free to teach me otherwise
Posted: Jan 28th, '17, 10:32
mex wrote:Metal-film resistors are less noisy than carbon ones
Thermal noise is in all types of resistors. It is dependent on resistor value and temperature.
Carbon resistors suffer from a couple of problems that metal film resistors don't. For example, they can drift in value over time and with temperature. Even just soldering a carbon resistor into a board may change its value by more than 5%. As far as noise goes, carbon resistors exhibit significantly more flicker noise (1/f) than metal film resistors do. This is a good topic to research online, but be wary of documents without graphs.
Posted: Feb 4th, '17, 00:05
by anotherlin
http://www.vishay.com/docs/28771/basics.pdf
Take a look at table page 5.
I absolutely agree with your remark regarding noise increasing with resistor value.
However, for the same (big) value, let's say 2M2, metal will be less noisy compared with carbon.
As I already said, in our case, this is irrelevant, the original 808 was built with the most common, if not the cheapest, components available. This is not hi-fi or a scientific instrument.
