Going slowly and testing every single component along the way. Testing the voltages at the IC's and then triggering the voice with the 5v into the 'Trigger' point on the back of the PCB.
All voices are good so far, apart from the Middle Tom.
There seems to be no tonality (Oscillators) in the voice. Only the Noise part. I'm assuming this is incorrect and that it should have the tonality/pitched part of the voice triggering it in this fashion?
I have gone over all polarized components and all are correctly placed. I have also buzzed out continuity between the IC socket and the solder pad on the other side of the PCB to check they are making connection.
I did find a broken trace (These look like they might break easily) and fixed it with a resistor leg.
See the photos below, can anyone see anything I may have missed?
Thanks
