Page 4 of 4
Re: firmware update problem 1.017 -> 1.0xx
Posted: Feb 2nd, '17, 09:12
by Reggiechacha
I've tried to burn the boot loader into a new chip but couldn't get it to work. I tried all of the possible changes and fixes mentioned in this thread but nothing worked.
In the end I uploaded the Yocto boot loader via Arduino as per instructions on the Yocto software thread. This worked and have now been able to upload the latest firmware.
Posted: Feb 3rd, '17, 11:30
by junk16
Reggiechacha,
Reggiechacha wrote:I've tried to burn the boot loader into a new chip but couldn't get it to work. I tried all of the possible changes and fixes mentioned in this thread but nothing worked.
This week, I got new chip and installed nava 1.020 and boot loader via ICSP. its success.woking fine.
its curious case of yours
Posted: Feb 7th, '17, 18:45
by Reggiechacha
For some reason, despite changing the com port the cmd would not find a pathway.
However I need to revisit this. My encoder is not working with v.020 so I need to try and reinstall. Works fine with v.018
Posted: Dec 21st, '17, 13:30
by druu
hi all,
i'm having trouble with my Nava build (
viewtopic.php?f=24&t=1093&start=20). I'm getting voltages all correct but I suspect something up with Atmega at this point.
I've tried flashing using the steps outlined earlier in this thread; every avrdude command line results in this:
Code: Select all
C:\tools>C:\tools\bin\avrdude.exe -c avrisp -p m1284p -P COM3 -b 19200 -u -e -U lock:w:0x3F:m -v
avrdude.exe: Version 6.1, compiled on Mar 13 2014 at 00:09:49
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\tools\bin\avrdude.conf"
Using Port : COM3
Using Programmer : avrisp
Overriding Baud Rate : 19200
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel AVR ISP
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude.exe: Device signature = 0x000000 (retrying)
avrdude.exe: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude.exe done. Thank you.
Is my chip at fault here? I've tried with both Arduino Uno directly (ensured pins matched) and also tried using Nava's own power source to no avail.
Any help appreciated!
Posted: Nov 3rd, '18, 19:53
by mkho
Okay so I am having issues understanding how to reflash my ATMEGA128 chip that came with 1.024 NAVA OS with the latest update.
I have an arduino UNO, as well as an AVR ISP MKII.
Is it as simple as popping out the atmega chip on the uno, and swapping it with the NAVA atmega, connecting the AVR to the arduino board, and then uploading the appropriate software to the chip via an arduino sketch?
a little confused by all of this.
Posted: Aug 12th, '21, 21:01
by nillwatson532
I am really eager for a fix for this as well.
One of my two Nava's updated successfully but the other would not after dozens of attempts of all different settings and software.
I have an Arduino Uno R3 which I believe can be used as an I(C)SP.
I attempted to follow online directions to use Arduino Uno to burn a new bootloader to the Nava ATMEGA chip on a breadboard,
but I couldn't get it to work.
I could access the chip but couldn't successfully write anything to it,
how to set the fuse bits and accomplish this is not very clear.
Posted: Apr 23rd, '22, 23:47
by druu
mkho wrote:Okay so I am having issues understanding how to reflash my ATMEGA128 chip that came with 1.024 NAVA OS with the latest update.
The NAVA has an ICSP header next to the 1284p chip. You should connect your avrispmkII to this header but something to note; MISO and MOSI pins are swapped so ensure you flip these. Also, the avrispmkII does NOT provide 5v power to the NAVA so you'll need to still power the device for programming.
Code: Select all
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -u -e -U lock:w:0x3F:m -v
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -u -U efuse:w:0xFD:m -v
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -u -U hfuse:w:0xDC:m -v
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -u -U lfuse:w:0xD6:m -v
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -U flash:w:Nava_v1_028beta.hex:i -v
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -U flash:w:BootNava.hex:i -v -D
avrdude -c avrispmkII -p m1284p -P usb -b 19200 -U lock:w:0x0F:m -v
