Re: Official Yocto BUGS list
Posted: Jan 27th, '17, 09:10
As I'm preparing for a live set using the yocto as a master, I'm stumbling across more bugs, will share them here:
BUG: There's some issue with Copy Paste.
Sometimes when you copy and switch to paste mode, it is impossible to select a pattern.
Best way is to select a pattern first in copy mode and then go to paste mode. That works about 75% of the time, the other 25% it seems to "crash", which usually means it defaults back to bank 1 (e.g. when you were in bank 4) and/or you have to visit pattern play first to make it behave normal again.
Also very annoying with the Copy Paste is that it doesn't seem to follow the "bank" context of Pattern Play, which is confusing as one must remember to switch to the correct bank every time.
EDIT: seems this had to do with a bad mode selector switch or solder joint, as touching the knob causes this behavior.. Hopefully it will hold till after my liveset
POSSIBLE BUG: Not 100% sure as I haven't been able to reproduce it, but when copying a 32 step pattern I noticed some of my accents were missing. Could be human error though, but I mention it nonetheless.
EDIT: had this happen several times again yesterday
FEATURE REQUEST: Roll mode allows to change the rate with the encoder. But it only allows for increased rate, while 1/8ths and maybe even 1/4ths would be cool too.
