Testing the LCD
  • Mine had cold solder joints. After resolder several times it worked. It was 3 or 4 times and heat it longer than normal.
  • Croodey wrote:Mine had cold solder joints. After resolder several times it worked. It was 3 or 4 times and heat it longer than normal.
    I'll give it a go - I've got the datasheet here: http://www.mouser.com/ds/2/291/NHD-0216 ... -29271.pdf so I'll check I've got power on pins 15/16
  • Nah I think I've killed it somehow... there's power at the pins, but no continuity from the pins to where the backlight is powered. And if I short the pin to the backlight it glows, but I have no display...
    I think I'll just get a new one for the sake of £8..
