- Posts 66
Hi, i only hear a verry low trigger signal on the Handclap. Changed the BA6110 - no results.
Q38 was damaged. I have changed this and now it overheat all BA6110 i put in. On Pin4 of BA6110 and both collector of 2sa798 are -15v.
Maybe someone can help me, or have some idea
Output signal
Trig
Noise
Env
ACC
Q37 Emitter
R234
+/-15v are on the marked places ok
Croodey on Sep 2nd, '16, 15:16, edited 1 time in total.
- Posts 96
Not an expert but this helped me :
http://hardware.freepage.de/raf909/ under the circuit analysis section you can see what does what in the clap section (but I guess you probably know all this already)
- Posts 66
Im not an expert too, but i know this page
- Posts 66
now... every new BA6110 is verry fast grilled. Without the BA6110 the Q38 only have on one leg -15v. On the place of BA6110 i have -15v on point 5 and +15v on point 9.
Without the IC, there is no other place for the pins of it with -15v. If i put in a Ba6110, i have the -15v on pin4 again. I wouldn´t kill one more of it
I will take some measurements of all points on the place for BA6110 tomorrow.
- Posts 66
Croodey on Aug 25th, '16, 15:39, edited 1 time in total.
- Posts 66
Measurements of place of BA6110 without the IC:
Pin1
Pin2
Pin3
Pin4
Pin5
Pin6
Pin7
Pin8
Pin9
The transistor on q38 works well. is not defect. If i put in a BA6110, there is on Pin4 -15V and the 6110 is killed in the same time.
Please, can anyone make reference measurements (Without the BA6110 please)
Thx!
- Posts 145
- Posts 66
my noise signal
- Posts 145
That looks crazy low, where are you reading that? You should be probing pin 9 of the second 4006.
What does your snare sound like?
+ on pin 9 and - on pin 5 is how it's supposed to be
- Posts 66
I read it on the point noise in the clap-part. I don't know how high it should be.
The snare works - only tone and snappy doesn't.
