[SOLVED] Weird issue with some step keys
Posted: Aug 21st, '16, 11:00
by GryphonP3
Hey guys. Just Finished up a build and everything works well except a couple step buttons (namely 9, 10, 13 & 14)
They're acting all around funky. In pattern write mode, the first time I press any of these buttons, it will activate them properly, but then any adittional presses will have no effect. I can continuously press them and they will not turn off, then a few passes of the active sequencer through them will either turn them into accents or turn them off, kind of randomly.
When I start the Nava and press Play, step 9 starts off lit. The first time the sequencer plays it, it becomes accented, then nothing else happens to it on additional pass throughs. Step 13 begins flashing after the sequencer has been running a little while.
Also, in pattern write mode, if I press Select Instrument, Mid Tom will immediately be selected. If I try to select any other instrument, it will immediately bounce back to Mid Tom within a couple miliseconds unless I release the Select Instrument button faster than that (pretty much pressing it with an instrument key simultaneously.)
I have desoldered and resoldered and no dice. Looking for any help on this, as its become pretty frustrating. Any ideas what area to focus on? It seems like a software issue, as no resoldering I have done has helped.. I will try to pop the non-functional step keys out and swap them with ones from the working steps just to confirm that it is not an issue with those buttons. I dont think it is though, since the problems dont seem to be something caused by faulty hardware. When I press step 9 for instance, it will sometimes also turn on step 10. The first press of these also always works, so its not like contact is not being made - its just the way they behave once pressed is not proper.
Re: Weird issue with some step keys
Posted: Aug 21st, '16, 11:45
by GryphonP3
Just realized that my PSU is 16VAC, not 15V. Any chance this would cause any issues? Seems weird since it all works well except these issues with the sequencer..
Posted: Aug 21st, '16, 21:52
by GryphonP3
Just checked and these problems still persist even with no step keys installed at all in these positions. Does anyone know which parts on the sequencer section could cause spazzy behavior like this? I will take a little video in a bit to better describe the behavior. Anyway, its not an issue with the step key hardware itself.
Posted: Aug 21st, '16, 23:19
by GryphonP3
Here is a video showing the issue
Posted: Aug 22nd, '16, 04:37
by Rowan
I'd be looking around IC104 to start with. IC104 is the shift register that loads the button states of the step 9-16 keys to the MCP.
If you have installed the chip in sockets the easiest thing to is to swap IC100 and IC104. IC104 in the casing the issue the problem should move to the step 1-8 group of keys.
If you haven't socketed the chips order a new 74HC165 and replace IC104.
This is what I would do anyway.
Posted: Aug 22nd, '16, 16:56
by GryphonP3
Rowan wrote:I'd be looking around IC104 to start with. IC104 is the shift register that loads the button states of the step 9-16 keys to the MCP.
Swapped IC100 & 104 and the problem still persists :/ thanks for the start thouh!
Re: [SOLVED] Weird issue with some step keys
Posted: Aug 22nd, '16, 21:49
by GryphonP3
Solved the problem by reflowing the associated caps. One of them was not making a good connection and messed up all 4 keys! Now working 100% beautifully!
Posted: Sep 16th, '25, 07:11
by will
homedepot.com/mycard is the online online portal for Home Depot credit cardholders. It allows you to activate your card, make payments, view statements, track rewards, and manage account settings securely from any device.
homedepot.com/mycard is the online online portal for Home Depot Credit Card holders. It allows users to activate new cards, make payments, view and manage statements, track rewards, and access account services securely from any device.
homedepot.com/mycard lets you manage, pay, and activate your Home Depot Credit Card online.
homedepot.com/mycard is the online, secure online portal where Home Depot credit cardholders can log in to view statements, make or schedule payments, activate new cards, check balances, track transactions, and manage account settings—all accessible on any device
homedepot.com/mycard is the online online portal for Home Depot Credit Card holders, allowing you to activate your card, make payments, view statements, track transactions, and manage all account settings securely from any device. It provides a convenient and centralized way to handle your Home Depot card activities without visiting a store.
Posted: Sep 16th, '25, 07:14
by will
homedepot.com/mycard ets you manage, pay, and activate your Home Depot Credit Card online.
homedepot.com/mycard is the online online portal for Home Depot Credit Card users, allowing you to activate your card, make payments, view statements, track rewards, and manage your account securely from any device.
Manage and pay your Home Depot Credit Card at homedepot.com/mycard
The URLhomedepot.com/mycard serves as the online, secure portal for Home Depot credit card holders—whether consumer or commercial—allowing them to log in, activate, manage, and make payments on their card account easily and efficiently.
The URL homedepot.com/mycard redirects to the Home Depot Credit Center, where customers can manage their credit card accounts, apply for new cards, and access financing options.
Posted: Sep 16th, '25, 07:17
by will
homedepot.com/mycard lets you manage your Home Depot credit or gift card online, including checking balances, making payments, and reviewing account activity.
Visit homedepot.com/mycard to manage your Home Depot credit or gift cards easily online.
homedepot.com/mycard is the online portal for managing your Home Depot credit card account. Through this site, cardholders can activate new or replacement cards, view balances, make payments, and access special financing offers.
homedepot.com/mycard is the online page where Home Depot credit card holders can manage their accounts, pay bills, and access exclusive offers and rewards.
homedepot.com/mycard is the online portal for Home Depot credit cardholders to activate cards, view balances, make payments, and manage their account online.
