What MIDI clock are you using?rv0 wrote:sebiiksbcs wrote:me using hardware midi clock
Do you recommend having one in the studio? As of today, I'm using Roland's SBX-1 to sync all the gear...
F.
TAP is not merged yet with master, you can find the manual change proposal here:FlavioB wrote:Thanks for your feedback, He - one thing is not mentioned in the updated manual: the TAP feature.
BR,
F.
Apart from the logic in the code, the mechanical properties of the TAP button are quite poor for this use, making late triggers happen more often, and as such getting on the wrong step.helectromagneticus wrote: Your impressions about Tap Write mode are similar to mine. It's a really cool feature, but sometimes the drum hit doesn't play and sometimes my tap goes in the wrong beat. Looking at rv0's code, it should be possible to fix both of those things in time.
Fine for me! Thanks.rv0 wrote: TAP is not merged yet with master, you can find the manual change proposal here:
https://github.com/HomoElectromagneticu ... anual.adoc
Fully agree with the mechanical properties not really being of much help.Apart from the logic in the code, the mechanical properties of the TAP button are quite poor for this use, making late triggers happen more often, and as such getting on the wrong step.
Ideally a pin-compatible replacement should be found for both TAP and START, that has a nice vertical tactile action.
Thanks again! No hurry - we will patiently wait and enjoy new firmware releases whenever they are published!As for the code part of notes not triggering or taps going on the wrong beat, I saw the same behaviour on the TR-606, I still have to find myself an 808 to play with. I agree there is room for improvement.
There's some logic in the code to avoid double triggers, but since I added that some drumhits indeed don't play. Will have to have another look, though it won't be before the weekend.
 yocto_firmware_1_0_g_RV0_COMBINED_4.syx
 yocto_firmware_1_0_g_RV0_COMBINED_4.syx  Oh, interesting feature request...gihaume wrote: Now I would like to send the pattern notes to the MIDI output to record it in another sequencer... any thoughts about this ?
