Vincent,
Could you share hex file for 1.024 firmware, pls?
thanks
lukasz
Nava v1.0 Firmware
Also keen for this, please share the hex for 1.024.lukep_gdansk wrote:Vincent,
thanks
lukasz
Last update v1.025 online (HEX file included)
Did the update and no more problem with Expander mode, thanks!e-licktronic wrote:Last update v1.025 online (HEX file included)
Does the 1.025 update work without the MUX mod? The reason I ask is I'm sceptical about doing the mod as I've read it can be problematic on some Nava's
Thanks
Thanks
No. The last update pre mux is .023. If you have a desoldering iron or you're a ninja at desoldering its well worth giving it a go. You can always revert back. Tbh even if you cut the chips out it wouldn't be expensive to go back.Behaviour wrote:Hi,
Thanks
can anyone confirm they have the mux_sh boards successfully working with a Nava v1.02 kit running firmware v1.025?
I am having intermittent issues with my HH, crash & ride.
Thank you!
Thank you!
Yes works for me ... look here viewtopic.php?f=24&t=1724#p10568Behaviour wrote:Hi,
Thanks
Grttzzz,
Danny
3x v1.02 working with the boards here, although I had one pair of MUX_SH boards causing problems in the digital section (OH delay sound). What I do have on all v1.02 are extreme volume differences among each voices. The RIM is 3 times louder than the BD for example.
hey klang generator,KlangGenerator wrote:3x v1.02 working with the boards here, although I had one pair of MUX_SH boards causing problems in the digital section (OH delay sound). What I do have on all v1.02 are extreme volume differences among each voices. The RIM is 3 times louder than the BD for example.
any tips on how to get problematic mux boards working?
or is it a matter of building them until you get a working pair?
