Nava v1.0 BOM [5/18/16 IMPORTANT BOM UPDATE]
You were too fast. I could have made a package with all the missing parts and send it to you from Cologne...
Oh snap, now I know better. Thanks for the offer though!
Hey there,
I cant seem to find a 0.68uf electrolytic at Mouser or Reichelt, I have carts I am adding to at both sites but niether have the caps, Mouser has ran out and will not be getting more for 21 weeks and the way things are at the moment may be even longer.
Is it possible to use a non electrolytic for C21 C23 in the mean time.
Thank a lot
Thank a lot
Hello kid303, are you referring to the "Nichicon UKL2AR68KDD - Aluminum Electrolytic Capacitors - Radial Leaded 100volts 0.68uF 85c 5x11 2LS"?kid303 wrote:Hey there,
Thank a lot
If so, I was able to find it here:
https://www.digikey.com/product-detail/ ... ND/2598596
Hello, does anyone know where I can find this item? It isn't available on Mouser and I can't find it anywhere else. Are there any alternative film capacitors that can be used as a replacement that you can recommend?
Xicon 23PS147 - Film Capacitors STYRENE 50V 470PF
https://www.mouser.com/ProductDetail/23PS147
PortableFishy
PortableFishy
Here in Europe they are available at Mouser. Don't know if that helps.PortableFishy wrote:Hello, does anyone know where I can find this item? It isn't available on Mouser and I can't find it anywhere else. Are there any alternative film capacitors that can be used as a replacement that you can recommend?
PortableFishy
https://www.reichelt.de/styroflex-capac ... l_11&nbc=1 takes you to Reichelt in Germany who has them. Or, you could go with a Mica cap.
Thanks for the updates, it looks like Mouser has it back in stock
Does anyone know why the Mouser BOM includes these smaller sized (1.7mm diameter / 3.4mm length) resistors? They have a smaller physical size compared to the rest of the resistors in the BOM:
MFS1/4DCT52R3902F - Metal Film Resistors - KOA Speer - Through Hole 39K ohm 1%
https://www.mouser.com/ProductDetail/KO ... wYLw%3D%3D
MFS1/4DCT52R5602F - Metal Film Resistors - KOA Speer - Through Hole 56K ohm 1%
https://www.mouser.com/ProductDetail/KO ... mA3Q%3D%3D
Can we use these resistors that have equivalent values but in a normal physical size (2.3mm diameter / 7.1mm length) instead?
MF1/4DCT52R3902F - Metal Film Resistors - KOA Speer - Through Hole 1/4W 39K ohm 1% 39K OHM 1%
https://www.mouser.com/ProductDetail/KO ... nLtA%3D%3D
MF1/4DCT52R5602F - Metal Film Resistors - KOA Speer - Through Hole 1/4W 56K ohm 1%
https://www.mouser.com/ProductDetail/KO ... REMA%3D%3D
Hi all,
What is the last BOM for the 1.02 PCB ?
This one https://www.mouser.fr/ProjectManager/Pr ... 26a285d084 missed some resistors and there are some unavailable components...
Thanks
EDIT : No news ?
Thanks
EDIT : No news ?
