Mine arrived last week!poser1 wrote:It's great to hear that people are receiving their cases! I was wondering if anybody in the states has had one arrive yet? Thanks...
Extra9 - NAVA Expansion Kits
hy, i have problems with BD attack and noise, and SD snappy since i've installed the extra 9 pcb. They do nothing, without pcb the function was ok. have anyone the same problem? Greetings.
I'd say IC33 died. To find out, remove IC33 and place it's companion (IC32) inside the socket.kmosch wrote:hy, i have problems with BD attack and noise, and SD snappy since i've installed the extra 9 pcb. They do nothing, without pcb the function was ok. have anyone the same problem? Greetings.
Haven't gotten mine yet. But I'm in California might take a little longer.
KlangGenerator wrote:I'd say IC33 died. To find out, remove IC33 and place it's companion (IC32) inside the socket.kmosch wrote:hy, i have problems with BD attack and noise, and SD snappy since i've installed the extra 9 pcb. They do nothing, without pcb the function was ok. have anyone the same problem? Greetings.
so i get 2 new mitsubishi 4006er, both was died. so SD and Handclap is ok, BD Attack and Noise do not. On R10 i have the Signat from the 4006, but how looks the signal at the test point for noise? the same?
Are any kits still available (no case)?
My case from Kacper finally arrived yesterday! Looks good so far but I haven't checked yet to see if everything lines up correctly with the PCB...
poser1 wrote:My case from Kacper finally arrived yesterday! Looks good so far but I haven't checked yet to see if everything lines up correctly with the PCB...
Lucky guy i'm still waiting for mine
Can you share picture of yours ?
Sure, I took some photos but can't figure out how to post them... shall I just PM them to you?
I had the same issue with mine after the Extra9 upgrade. Turns out the problem was with my ability to clearly read the instructions. I had all of the wires going to the attack pot and didn’t see that the 2nd wore is actually supposed to go to the pcb. Once I fixed that everything worked 100%. Hopefully your issue is something simple too.kmosch wrote:hy, i have problems with BD attack and noise, and SD snappy since i've installed the extra 9 pcb. They do nothing, without pcb the function was ok. have anyone the same problem? Greetings.
