"Half-baked" is a bit hard. 5ms of delay to react to MIDI Notes is pretty usual. The Trig outputs were corrected in one of the last official releases but its source code wasn't published so that's why it didn't come directly in the unofficial ones.
I'm experiencing issues with updating the firmware. the machine times out and goes back into play mode before the file is done transmitting. Should there be LED progress indication? I've tried using syesx librarian and C6 both with a delay of 200ms.
Teef wrote:So good! Thanks for fixing a half baked machine.
Teef, how did you manage to get your update across?
I finally dived into this code, first time I do anything Arduino, so be gentle
I added Midi output for the last 4 "unused" instruments (13 14 15 16) to drive the first 4 channels (1 2 3 4) of my Korg Volca Sample to have some more sounds available during live performance and keep my hands on the Yocto.
No merge request as it is quite specific for Korg Volca Sample and it could be made a lot better with things like:
add midi channel selection
add midi note selection
add velocity selection
add accents
I might add those things late rather than soon, I wanna make some music now
But I hope this might inspire anyone else considering diving into Yocto V1 development
rv0 wrote:I finally dived into this code, first time I do anything Arduino, so be gentle
add accents
I've been working on Pattern Dump/Restore via SysEx too..
But I'm kinda stuck atm, the data I send is not what I expect it to be, think I'm doing something wrong with Wire.read() or the splitting into 7 bit packages.. Data I receive looks incorrect and it never sends the SysEx end byte.
EDIT: damn, by posting this, I had a quick glance at my code again and think I found the issue.. Gonna test it tonight!
