Go through the lists, if you can't see your bug, post it here with instructions on how to replicate and I'll add it to the list.
If you can, please try things in "Plausible bugs" list and post results if you can replicate the bugs!
Known bugs:
- sequencer lag when saving a pattern while sequencer is running [Has to be fixed]
- accent on the cl hihat is not saved
Plausible bugs:
- Open hihat is altered by following global accent steps (e.g.try OH on step 3 with long decay and set step 5 with globel accent) [Has to be tested]
- random level problems at certain steps independent of accents (e.g. BD on step 1 in pattern 1 has higher lvl than bd on other steps, can only be solved by initializing the eeprom at the moment) [Has to be tested]
- tap mode digital sounds cut if another sound is tapped
- responsive to shuffling MIDI clock?
Fixed/Not bugs:
- Hi Tom level [fixed in the v1.019 firmware]
- Mid Tom decay [Not a software issue, you should have a electronic issue on your Mid TOM circuit]
- Bass drum buzz (improved after fix but still noticeable) <problem with PCB?> [Fixed with the BD Mod on PCB v1.0l and not a software issue]
- slightly higher noise floor at the snare drum [Same as the original TR909]
