				- Posts 373
				- Posts 373
				- Posts 96
						Nice! What kind of wires did you use for the power supply to main board connections?
				- Posts 373
						beeb wrote:Nice! What kind of wires did you use for the power supply to main board connections?
Hi beep,
header used is this one:
https://www.conrad.de/de/buchsenleiste- ... 78646.html
The good thing about these MTA headers is that there is no need for crimping and the cable connection still is very strong. In my TTSH I am only using these headers. I also have a very good crimping tool from Knipex, but I missed to order the 5P connector for the power supply. That's why I took the MTA.
Cables are these:
https://www.conrad.de/de/litze-radox-15 ... %20Details
				- Posts 96
						Those connectors look good indeed, thanks for the info!
				- Posts 44
						Finishing 6 of them is amazing, and your work looks fantastic from the pictures
				- Posts 36
Aarrgghh on Feb 13th, '17, 15:36, edited 1 time in total.
				- Posts 373
						Very nice! I see that you've mounted the display on the component side. How does this fit with the Erica Synths case? With happymum's case there was quite a lot space left between top panel and display when mounting it that way...
				- Posts 36
						KlangGenerator wrote:Very nice! I see that you've mounted the display on the component side. How does this fit with the Erica Synths case? With happymum's case there was quite a lot space left between top panel and display when mounting it that way...
The display is mounted as close as possible to the pcb, and with the erica case and plexi there is about .5 mm between the display and the plexi. It's a very nice fit!
				- Posts 134
