Build Finished - HiHat Decay not working [SOLVED]
IC112 & 111 just run the triggers right?
Yes, I know. I actually don't believe either that this will fix anything. But if you have them in sockets it would be worth a try. I found one user here reporting about HH decay problems in relation to those ICs...hofmann25 wrote:IC112 & 111 just run the triggers right?
Really? Where is the thread?KlangGenerator wrote:Yes, I know. I actually don't believe either that this will fix anything. But if you have them in sockets it would be worth a try. I found one user here reporting about HH decay problems in relation to those ICs...hofmann25 wrote:IC112 & 111 just run the triggers right?
Tried a new 74HC595N for IC112. Decay still not functioning...
I probed with a scope from Q72 to IC67 pin 7.......
Refresher of the problem. Decay is little taps instead of a HiHat Decay...
https://www.youtube.com/watch?v=efsv6XGJ4PY[/video]
I did notice during the probing that R452 is connected to ALL 3 pins of VR23. Pin 1 should NOT be connected right?
AND it looks to me that the problem (Little taps instead of the decay) re-appears at IC67A PIN 1
Q72_Base
Q72_Collector
Q72_Emitter
Q73_Base
Q73_Collector
Q73_Emitter
VR21_2 & 3
VR21_PIN1
C135 + Side
R452
VR23_PIN_2
VR23_PIN_3
R454_455 connection
Q74_B
Q74_C
Q74_E
R453_Q74_SIDE
R453_OPAMP_SIDE
IC67_A_PIN_1
IC67_A_PIN_2
IC67_PIN_1_SIDE
R453_SIDE
R489_R481_CONNECTION
R481_ACCENT_IN_SIDE
R484_Q84_SIDE
R484_IC67_A_SIDE
Q84_PIN1
Q84_PIN2
Q84_PIN3
Q84_PIN4
Q84_PIN5
Q52_E
Q52_C
Q52_B
IC67_B_PIN_7
Q72_Base
Q72_Collector
Q72_Emitter
Q73_Base
Q73_Collector
Q73_Emitter
VR21_2 & 3
VR21_PIN1
C135 + Side
R452
VR23_PIN_2
VR23_PIN_3
R454_455 connection
Q74_B
Q74_C
Q74_E
R453_Q74_SIDE
R453_OPAMP_SIDE
IC67_A_PIN_1
IC67_A_PIN_2
IC67_PIN_1_SIDE
R453_SIDE
R481_ACCENT_IN_SIDE
R484_Q84_SIDE
R484_IC67_A_SIDE
Q84_PIN1
Q84_PIN2
Q84_PIN3
Q84_PIN4
Q84_PIN5
Q52_E
Q52_C
Q52_B
IC67_B_PIN_7
From e-licktronic just now...
"All mesure you gave me are ok.
The problem you describe as "little taps" is a software issue and we are working on it
You will be advice when it will be solved."
Does anyone else's HH sound like this?
https://www.youtube.com/watch?v=efsv6XG ... e=youtu.be[/video]
So mine IS screwed?KlangGenerator wrote:No. Mine sounds alright. I guess what Vincent means is this:
https://vimeo.com/208004149
I'm afraid yes. There is definately something wrong if your CH just clicks like in that video.hofmann25 wrote:So mine IS screwed?KlangGenerator wrote:No. Mine sounds alright. I guess what Vincent means is this:
Ok so. VR23 is faulty. 1M - 1A 05.KlangGenerator wrote:I'm afraid yes. There is definately something wrong if your CH just clicks like in that video.
I de-Soldered it and there is no continuity between pins 2/3 & 1. When I place it back in circuit there is continuity between pins 2/3 & 1.
This is why OH Decay does not work and could be why the clicking/tapping is on CH...........
