Any reason an electrolytic wouldn't work? This appears to just be connecting an input of gate A to Vss.
I have some electrolytic's left over from my build, but I'd have to order a poly cap.
Hihats problems . Bug? [SOLVED]
Electrolytics are polarized, so your question is really:biftek wrote:Any reason an electrolytic wouldn't work?
- would a polarized capacitor do the trick
- what orientation would the polarized cap need to have (what direction)
I don't know the answers though.
Is this the same problem I have??? viewtopic.php?f=24&t=1262&start=10#p8090eleclove wrote:Hello, this problem I see that it has many people, this in the part of CH, is a problem of synchrony in the circuit, the sample of the Eprom is not launched correctly. You can see it but you must make a sequence like this to see the problem. .
The truth is that I went crazy with this.
-Write on HH CH ...
1, 7, 11 there is 7 stronger![]()
3, 9, 15 there is 9 stronger![]()
To solve, install a capacitor of 470K in the IC 4011. Pin 1 & 7.
The soundcloud link doesn't work anymore...
No, I'm sorry. It was something different...hofmann25 wrote:Is this the same problem I have??? viewtopic.php?f=24&t=1262&start=10#p8090eleclove wrote:Hello, this problem I see that it has many people, this in the part of CH, is a problem of synchrony in the circuit, the sample of the Eprom is not launched correctly. You can see it but you must make a sequence like this to see the problem. .
-Write on HH CH ...
