TL072 on IC110 on 1.01a board
  • When did you order the bom? I think you may have a later one related to V1.02. Check the "Nava BOM" post and its updates pinned at the top of the Hardware forum.
  • You need a TL074
  • Right, I do have a TL074 from the BOM that I ordered..
    Hmm, ok, but well TL074 work in conjunction with the MUX_SH board? A bit confusing.. Maybe I should just try it out and see what happens ;)
  • istel wrote:Right, I do have a TL074 from the BOM that I ordered..
    If your board are other than v1.02 you should use a TL074.
    Do not solder C517, C518 and C519.
