- Posts 20
Hi guys
I am building the NAVA atm and I have a 1.01a board - it's not clear in the guide exactly what to do with a 1.01a board, so I thought i'd ask here before having to unsolder stuff.
Here's a picture of my BD section.
I have connected a wire from P1' to P1 as described. But i am not sure what to do with the C89 cap - there's room for it on my board, and I have a 0.01 uF cap for it. But it also confused me a bit looking at the guide where the cap in C89 on the pictures says .47J100.
So, what do I do? Add 0.01 uF cap in C89, ignore it completely or what?
Cheers guys
Looking forward to having a Nava!!
- Posts 373
Do you have the new MUX_SH boards? If yes, you can leave C89 empty, as well as C517, C518, C519, C163 (SD), C164 (LT), C165 (MT), C166 (HT), C167 (RS), C168 (HC).
See tutorial here:
viewtopic.php?f=24&t=1549
If you don't have the boards yet you should get in contact with e-licktronic. They really improve the accent behaviour of your Nava!
- Posts 20
KlangGenerator wrote:Do you have the new MUX_SH boards? If yes, you can leave C89 empty, as well as C517, C518, C519, C163 (SD), C164 (LT), C165 (MT), C166 (HT), C167 (RS), C168 (HC).
See tutorial here:
No, i haven't heard about the MUX_SH boards. They are free for previous orders? The accent system isn't working properly without it? That's a bit of an error I have to say..
Related question; I have one last cap on BD - the C10. In the parts list it says it is a 10/16 uF Cap, meaning 10uF and 16V rating as far as i know. But there's only one electrolytic 10uF cap in the BOM, which is rated 50V. This should be ok to use, correct? This is the one I have from the mouser BOM
https://www.mouser.dk/Search/ProductDet ... M1HBK0511P
Cheers KlangGenerator!
- Posts 47
There is a thread on the forum to enter your name to receive MUX_SH boards. They are free if you enter your order number. I believe he is waiting to receive the next shipment of boards to fulfill the remaining orders. As heads up they are SMD (smallest package is 0805).
You can use the 50V cap. I'm assuming the 16V rating came from the original 909 specs. Much better to use the 50V rated cap.
- Posts 20
Acetate wrote:There is a thread on the forum to enter your name to receive MUX_SH boards. They are free if you enter your order number. I believe he is waiting to receive the next shipment of boards to fulfill the remaining orders. As heads up they are SMD (smallest package is 0805).
Thank you, I will do that.
Still not fully understanding what the MUX_SH board does - there's one quite technical description and what I gather from that, is that it improves the accent by speed and less opamps etc - in other words; it's a simpler solution and less prone to errors. Correct?
It's just a little annoying that this isn't mentioned in the build guide and there is no clear explanation of what to do for what reasons. Now i am a little stuck between building my Nava as it is or begin waiting for more parts to arrive ...
- Posts 47
Nava is a big build and big builds are confusing. I actually ordered a 1.02 board and the MUX_SH boards were missing from the order (an oversight by e-licktronic). Upon notifying Vincent he sent them immediately. I'm still waiting for mine to arrive but I completed my entire build except the MUX_SH boards. The only thing impacted will be accent will not work. You can get all your voices working and the sequencer tested (minus accent). You can omit a few parts from your 1.01a board by reading this
thread (also noted in the build guide for 1.02 boards). This will save you some desoldering time in the future.
It's a daunting task to build a Nava/Yocto. Just have patience and enjoy the ride.
