MUX_SH board mod tutorial
Postby e-licktronic » Oct 30th, '17, 15:15
Dear Diyer,
Here is a tutorial on how to mod your Nava with Mux_SH boards.
1/You must unsolder IC111 and IC114
If you don't have a good desolder iron you can cut each pin then unsolder pins one by one
2/You must unsolder C517, C518, C519, C89 (BD), C163 (SD), C164 (LT), C165 (MT), C166 (HT), C167 (RS), C168 (HC)
3/Solder J15 connector
4/Solder IC111 and IC114 Pins Headers
5/Solder CMS components on both Mux_SH boards. Take care of IC orientation, the 45°line have to match red line
6/Cut three piece of jumper wire female/female in the middle
7/Solder wires on the Mux_SH board. Take care to to put the same wire color on the pin +, GND and -
8/Solder Pin headers on the MUX_SH boards
9/Connect both MUX_SH board to the Main board. Take care IC111 and IC114 are in the opposite way.
And connect Jumper wires to J15
10/Now update the Nava firmware v1.024 (or higher) by holding steps button 1, 3 and 5 when power up the unit
Old accent value are still saved in your old pattern, to get it working properly you must write new pattern ;)
Enjoy
Site Admin
Re: MUX_SH board mod tutorial
Postby Altitude » Nov 7th, '17, 02:32
Sorry if I missed something but what does this device do?
Altitude
Postby blotvard » Nov 7th, '17, 02:42
Is it related to this post?
Also, if it works for the NAVA, would it work for the Yocto2? Assuming firmware update?
blotvard
Postby e-licktronic » Nov 7th, '17, 11:49
blotvard wrote:Is it related to this post?
Yocto² doesn't need Mux/SH board cause accent works perfectly ;)
Site Admin
Postby peskado » Nov 15th, '17, 21:58
Where I can buy it?
peskado
Postby lukep_gdansk » Nov 17th, '17, 15:13
If you want to buy pm me. I have one for sell.
cheers
lukep_gdansk
Postby KlangGenerator » Nov 17th, '17, 20:05
No need to buy. They are for free for all previous orders! Just enter your name and order number in the list...
KlangGenerator
Postby lukep_gdansk » Nov 18th, '17, 11:08
KlangGenerator - I sell build one.
Some ppl have second hand Navas also.
lp
lukep_gdansk
Postby KlangGenerator » Nov 18th, '17, 16:35
lukep_gdansk wrote:KlangGenerator - I sell build one.
lp
Ok, sorry for the misinterpretation, but from your post it was not clear that you are offering built ones. And peskado very much likely built his own Nava and will therefore get the boards for free from e-licktronic.
For unexperienced users with second hand machines it could still be pretty tricky to install the new MUX_SH boards, as they require desoldering the old ICs and fitting new sockets into the pads.
KlangGenerator
Postby peskado » Nov 18th, '17, 21:28
Thank you for your answer!
where i can find list?
lp
peskado
Next
Return to Nava Hardware
