My build is 70% completed but I have a few problems that I don't seem to be able to correct by myself.
Everything works as it supposed to, except that the bass drum is very quiet in comparaison to the rest of the instruments (master out and individual out). I've checked all the components value and they all seem right. I've tried swapping the UC with another one with no success. I've also noticed 3 things:
- When I turn the master volume pot I hear a slight crack and if I hold it on the exact position where it cracks I can hear the bass drum louder and distorted.
- I can measure +15v everywhere I'm supposed to but since yesterday I can't measure the -15v spots. I get strange values and at some point it seemed to stabilize around -17.9 or -20.1. I could measure it correctly before. Maybe something fried or I did a short with the multimeter. EDIT : The value seems to be -21.5v. (I've ordered a new regulator just in case)
- At some point when I tried to wiggle the J1 connector a bit, the kick seemed to be louder. So I reflowned the joints but it didn't do the trick.
Otherwise every other instruments seem to sound as they should and the OS and sequencer work as supposed.
Is it possible that a transistor is faulty? Is it a common thing?
I'm a beginner but willing to learn so any help would be greatly appreciated
Thanks in advance.
