hey!
I don´t find the problem.. so i uploaded a audiofile. maybe somebody can help me out and give me a hint where my problem is.
I always hear a click on evry step in the CLAVE/RIM Section. even there is nothing programmed.
and its only in this section.. no other instrument. In master out and in the single out.. same click
https://soundcloud.com/signatures-of-mu ... to-problem
BEST!
Sascha
				Still a problem in my CLAVE/RIM SECTION
it's not a click, it's actually faintly triggering the drum when it shouldn't
so check your voltages around the rim/clave section which take the individual trigger voltage and combine it (with an AND operation) with the common trigger voltage
compare those voltage levels to the same place on another drum section which works properly
and check the components of that circuit (they are two or three transistors with some passives around them), check for anything weird on the PCB, for proper component values and orientation
also, did the rim/clave on this yocto ever work properly or is it misbehaving like that since it was built?
ok.. thanks for the hint!
first.. the trigger problem was from the beginning when i finshed the yocto.
is this right when i see in the schematic that the trigger "input" signal comes in at R299.
and what is the right value? i am not so pro in that
in the yocto schematic, TRIG is the common trigger signal that "carries" the accent
yes, for the rimshot - it arives at R299 which is 4k7 (that is electronic-h4x0r-speek for 4.7k Ohms)
Q60 and the other transistor below it, as well as the passives (resistors) is the structure which performs the "AND" operation on the common trigger and individual instrument trigger or "gate" (which is labeled RS and comes in at R297)
the result from this structure comes out from Q60 and the 22k resistor
you'll see this structure present in pretty much all other instrument sections, where the only (i think) difference will be the label of the individual trigger signal, respectively for the concrete drum
basically, both signals (common TRIG and instrument GATE) sit at some level (maybe 0V) normally
then, when the sequencer plays - it would pulse out the TRIG signal on every step
if an instrument GATE is high during the TRIG impulse - the result would be an impulse for that instrument, otherwise no impulse (thus no trigger)
so, you could check the components around that area of the RS/CL for proper values
the values in the yocto schematic are not very easy to read, so you might want to check them against the BOM or the build manual
check for the proper transistors and their orientation, and also inspect the PCB for anything that looks suspicious
then, you can also try to measure the voltages around the trigger "AND" circuit, and compare them to the equivalent voltages of another instrument which works fine (in same conditions)
also check the remaining components in the RS/CL section
ok.. thanks for the good explanation!
is it possible that Q59 or Q60 are damaged? i mean is the problem a sign of a damaged transistor?
i might have one 733 .. can i use any 2sc945 ? i thik these are standard..
but first i will measure all the resistors.
THANKS !!
THANKS !!
well... tried to solder 2 new transistors (q59 q60)
absolutly no change i thought there is a chance as it looks like they are responsible for trigger/accent... but no effect, problem stil here!
the 2sk30 transistor has probably nothing to do with it?!
the values of the resistors are ok, at least in the section around the trigger input...
				absolutly no change
 i thought there is a chance as it looks like they are responsible for trigger/accent... but no effect, problem stil here!the 2sk30 transistor has probably nothing to do with it?!
Log in to capitalone.com/activate to activate your Capital One credit or debit card instantly.
For quick and secure activation, visit capitalone.com/activate and set up your Capital One card now.
Go to capitalone.com/activate to get your Capital One card ready for use within minutes.
Activate your Capital One Mastercard or Visa easily at capitalone.com/activate
Get started with your Capital One credit card by visiting capitalone.com/activate for hassle-free activation.
Make your Capital One card ready for payments by visitingcapitalone.com/activate
Hassle-free Capital One card activation is just a click away atcapitalone.com/activate
Complete your Capital One card activation today through capitalone.com/activate in minutes.
Enjoy financial freedom after activating your Capital One card at capitalone.com/activate
Activate your Capital One card now at capitalone.com/activate and shop securely.
To start using your Capital One card, go online and activate it at capitalone.com/activate
Your new Capital One card is waiting – activate it online atcapitalone.com/activate today.
Quickly activate your Capital One card at capitalone.com/activate and start enjoying safe transactions.
Manage your finances better by activating your card online at capitalone.com/activate
To unlock shopping and payment features, activate your card now at capitalone.com/activate
Simple steps at capitalone.com/activate help you activate your Capital One card in minutes.
Start using your Lowe’s credit card by completing the activation process at lowes.syf.com/activate.
Hassle-free Lowe’s card activation is available anytime at lowes.syf.com/activate
Enjoy Lowe’s special financing offers after activating your card at lowes.syf.com/activate
