Din Sync Slave - Does not see Reset
Postby punkdisco » Oct 4th, '15, 17:40
Hi all
I just tried Slaving the Yocto to Din Sync. It works fine but, it does not re-start from beat 1 rather, it carries on from the current pattern position.
I have tried the same cable/setup into a CR8000 and tb303 and these both work correctly, re-starting on beat 1 each time.
Is this a known issue?
Many thanks,
Paul
punkdisco
Re: Din Sync Slave - Does not see Reset
Postby rv0 » Oct 7th, '15, 08:41
what are you using as master clock?
rv0
Postby punkdisco » Oct 7th, '15, 12:25
rv0 wrote:what are you using as master clock?
Hi
The master DinSync is coming from a Kenton Pro Solo but I think the key thing is that both the cr8000 and tb303 work correctly from the Kenton, restarting from the first beat when you press Start.
Is this working for anyone else?
Paul
punkdisco
Postby stevesavage » Jan 27th, '16, 23:04
Yep, I've have also found this issue when slaving from a TR606.
stevesavage
Postby FlavioB » Aug 9th, '16, 19:51
Hi everybody.
I'm facing the same issue: I'm slaving my Yocto from a ZAQuencer and with DinSync the pattern simply continues, doesn't restart at beat 1.
Is this the default behavior on the Yocto?
Can this be modified (hard- or software)?
Thanks for your help!
FlavioB
Postby Ele » Sep 16th, '16, 15:44
Same here. Please update the firmware!
Also it will be great if it could be midi sync'ed/start in PT Edit Mode also and not just PT Midi. It's a bit annoying to always switch back to PT Midi when sync to a daw.
Ele
Postby FlavioB » Sep 16th, '16, 15:51
Ciao Ele.
You can have a look here:
viewtopic.php?f=17&t=991&p=6315#p6315
Maybe you can add your wishes there...
FlavioB
Postby FlavioB » Jun 4th, '17, 19:02
Bump!
Any news about this issue? It's pretty annoying...
FlavioB
Postby FlavioB » Sep 10th, '17, 12:21
Hi there.
I recently bought a Roland SBX-1 so I gave it a try connecting it to the Yocto with DinSync.
With the SBX-1 the Yocto is correctly starting at step 1 when you stop and restart it. So that would be great, but... BUT the first step is somehow "degraded" (acoustically). I mean, having the BD on the first step, you can definitely hear that it sounds pretty "wrong" (can't describe it in words, seems like it's missing the attack), whereas all following BDs are sounding perfect (and also step 1, after the pattern loops).
Can anybody test this with an SBX-1 as well and report back?
Anybody knows where the issue could stem from?
Thanks,
FlavioB
Postby antto » Sep 17th, '17, 08:29
FlavioB i don't have SBX-1
can't you record a small audio clip that demonstrates the issue?
antto
Next
Return to Yocto v1.0 Software
